--- title: "Sparkline Chart" description: "The sparkline chart is a minimalistic chart component that displays a line-chart history for a single datapoint. " --- # Sparkline Chart > The sparkline chart is a minimalistic chart component that displays a line-chart history for a single datapoint. ![A Sparkline Chart: a small, borderless line chart with no axes or labels, tracing the recent history of a single datapoint as it oscillates up and down, with a dot marking the most recent value at the right edge.](sparkline0.png) **Component Palette Icon:** ![Sparkline Chart component palette icon](spark1.png) ## Description The sparkline chart is a minimalistic chart component that displays a line-chart history for a single datapoint. Sparklines were invented by Edward Tufte as a way to show a great deal of contextual information in a very small amount of space. Sparklines are typically used to display the recent history (up to current time) of a datapoint so that the viewer can quickly discern the recent trend of a datapoint: is it rising? falling? oscillating? etc.. To use a sparkline, bind its Data property either to a Tag Historian realtime query, or to a database query. There should be two columns in this dataset: the first one a date column, the second a number. Each row will become a datapoint on the chart, and the dataset must be sorted by time in ascending order. Instead of using axes to convey scale, the sparkline can display a band of color across the back of the chart which indicates the desired operating range of the datapoint. In this way, it is instantly obvious when a value is in its expected range, above that range, or below. The sparkline automatically configures its internal axes based on the data given to it. To give it a fixed range, simply fill in the Range Highand Range Low properties. ## Properties | Name | Description | Property Type | Scripting | Category | |--- |--- |--- |--- |--- | | Background Color | The background color of the component. | Color | .background | Appearance | | Border | The border surrounding this component. NOTE that the border is unaffected by rotation. | Border | .border | Common | | Border Inset | The amount of space to inset the chart inside its border. | double | .borderInset | Appearance | | Chart Max | The value that corresponds to the upper edge of the chart. (Read only. Usable in bindings and scripting.) | Double | .chartMax | Uncategorized | | Chart Min | The value that corresponds to the lower edge of the chart. (Read only. Usable in bindings and scripting.) | Double | .chartMin | Uncategorized | | Cursor | The mouse cursor to use when hovering over this component. | int | .cursorCode | Common | | Data | The history data to draw in the sparkline chart. | Dataset | .data | Data | | Data Quality | The data quality code for any tag bindings on this component. | int | .dataQuality | Data | | Desired High | The high value of the desired operating range. If left blank (null), no desired range band will be shown. | Double | .desiredHi | Data | | Desired Low | The low value of the desired operating range. If left blank (null), no desired range band will be shown. | Double | .desiredLo | Data | | Desired Range Color | The color of the desired operating range band. Only used if the desired operating range is configured. | Color | .desiredRangeColor | Appearance | | First Marker Color | The color of the first value marker. | Color | .firstMarkerColor | Markers | | First Marker Size | The size of the first value marker. | double | .firstMarkerSize | Markers | | First Marker Style | The style of the first value marker. | int | .firstMarkerStyle | Markers | | First Value | The first (oldest) value in the dataset. (Read only. Usable in bindings and scripting.) | Double | .firstValue | Uncategorized | | High Marker Color | The color of the high value marker. | Color | .hiMarkerColor | Markers | | High Marker Size | The size of the high value marker. | double | .hiMarkerSize | Markers | | High Marker Style | The style of the high value marker. | int | .hiMarkerStyle | Markers | | Last Marker Color | The color of the last value marker. | Color | .lastMarkerColor | Markers | | Last Marker Size | The size of the last value marker. | double | .lastMarkerSize | Markers | | Last Marker Style | The style of the last value marker. | int | .lastMarkerStyle | Markers | | Last Value | The last (most recent) value in the dataset. (Read only. Usable in bindings and scripting.) | Double | .lastValue | Uncategorized | | Line Color | The color of the sparkline. | Color | .foreground | Appearance | | Line Width | The width of the sparkline. | float | .lineWidth | Appearance | | Low Marker Color | The color of the low value marker. | Color | .loMarkerColor | Markers | | Low Marker Size | The size of the low value marker. | double | .loMarkerSize | Markers | | Low Marker Style | The style of the low value marker. | int | .loMarkerStyle | Markers | | Max Value | The largest value in the dataset. (Read only. Usable in bindings and scripting.) | Double | .maxValue | Uncategorized | | Min Value | The smallest value in the dataset. (Read only. Usable in bindings and scripting.) | Double | .minValue | Uncategorized | | Mouseover Text | The text that is displayed in the tooltip which pops up on mouseover of this component. | String | .toolTipText | Common | | Name | The name of this component. | String | .name | Common | | Range High | A fixed value for the upper edge of the chart. If left blank (null), the upper range will be calculated automatically. | Double | .rangeHi | Data | | Range Low | A fixed value for the lower edge of the chart. If left blank (null), the lower range will be calculated automatically. | Double | .rangeLo | Data | | Styles | Contains the component's styles. | Dataset | .styles | Appearance | | Visible | If disabled, the component will be hidden. | boolean | .visible | Common | ## Scripting ### Scripting Functions This component does not have scripting functions associated with it. ### Extension Functions This component does not have extension functions associated with it. ### Event Handlers Event handlers allow you to run a script based off specific triggers. See the full list of available event handlers on the [Component Events](scripting\scripting-in-ignition\component-and-window-scripting\component-events.md) page ## Customizers This component does not have any custom properties. ## Examples ### Sparkline Chart with Low and High Limits ![A Sparkline Chart with a shaded blue band filling the desired range between the Desired Low and Desired High limits. The trend line stays within the band for the full history, ending in a dot at the most recent value.](sparkline2.png) | Property Name | Value | |---|---| | Range High | 100 | | Range Low | 0 | | Desired High | 75 | | Desired Low | 40 |
