--- title: "Pie Chart" description: "The Pie Chart component displays a familiar-looking pie chart. A Pie Chart displays a list of named items, each of which has a value that is part of a total." --- # Pie Chart > The Pie Chart component displays a familiar-looking pie chart. A Pie Chart displays a list of named items, each of which has a value that is part of a total. ![A Pie Chart drawn in the 3D style, divided into five color-coded wedges sized in proportion to their values, with a legend below the chart naming each wedge: Apples, Bananas, Kiwis, Oranges, and Grapefruit.](pie.png) **Component Palette Icon:** ![Pie Chart component palette icon](pie2.png) ## Description The Pie Chart component displays a familiar-looking pie chart. A Pie Chart displays a list of named items, each of which has a value that is part of a total. The total is the sum of the value of each item. The key to the Pie Chart component is the Data property, which contains the items that will be displayed as pie wedges. Typically, this dataset will be bound to a [SQL Query Binding](visualization-and-dashboards/property-binding-types/sql-query-binding/sql-query-binding.md) to pull dynamic data out of an external database. ### Extract Order Similar to other charts, the pie chart can actually accept data in two formats. You can tell the pie chart which format to use via its Extract Order property. The two extract orders are By Column or By Row . The following tables show the two styles for the data that created the pie chart in the screenshot. #### By Column | Label | Value | |---|---| | Grapefruit | 7 | | Apples | 15 | | Bananas | 56 | | Kiwis | 19 | #### By Row | Grapefruit | Apples | Bananas | Kiwis | |---|---|---|---| | 7 | 15 | 56 | 19 | ### Labels In addition to the color-coded legend, the pie chart can annotate each wedge with a label. The format of the label is controlled via the Label Format property. For example, the format string used in the screenshot is " {0} = {2} ({3}) " This is a pattern string that uses the following placeholders: * {0} - the item label * {1} - the item value * {2} - the item percentage ## Properties The 3D? Property on the the Pie Chart has been removed as of 7.9.8. Instead, the **Style** property should be use to configure a 3D Pie Chart. The depreciated property is listed further down this page. | Name | Description | Property Type | Scripting | Category | |--- |--- |--- |--- |--- | | 3D Depth Factor | The depth of a 3D pie as a factor of the chart height. | double | .depthFactor | Appearance | | Antialias | Draw with antialias on? Makes text smoother. | boolean | .antialias | Appearance | | Border | The border surrounding this component. NOTE that the border is unaffected by rotation. | Border | .border | Common | | Chart Title | An optional title that will appear at the top of the chart. | String | .title | Appearance | | Cursor | The mouse cursor to use when hovering over this component. | int | .cursorCode | Common | | Data | The data driving the chart. | Dataset | .data | Data | | Data Quality | The data quality code for any tag bindings on this component. | int | .dataQuality | Data | | Enforce Circularity? | If true, the pie cannot be an oval, even if the overall chart is. | boolean | .circular | Appearance | | Extract Order | Controls whether or not a pie plot views columns as pies, or rows. | int | .extractOrder | Data | | Foreground Transparency | The transparency of the pie (useful for 3D pies). | double | .foregroundAlpha | Appearance | | Label Font | The font for labels items, if there are labels. | Font | .labelFont | Appearance | | Label Format | Formatting String. '{0}' is the wedge name, '{1}' is the value, '{2}' is the percent. | String | .labelFormat | Appearance | | Labels? | Should labels be displayed near sections? | boolean | .labels | Appearance | | Legend Font | The font for legend items, if there is a legend. | Font | .legendFont | Appearance | | Legend? | Should there be an item legend below the chart? | boolean | .legend | Appearance | | Mouseover Text | The text that is displayed in the tooltip which pops up on mouseover of this component. | String | .toolTipText | Common | | Name | The name of this component. | String | .name | Common | | Outline Colors | The colors to use for the pie wedge outlines. | Color[] | .outlineColors | Appearance | | Outline Stroke | The width for the section outline stroke. | float | .outlineStroke | Appearance | | Plot Background | The background color for all plots, unless they override it. | Color | .plotBackground | Appearance | | Rotation | Draw the wedges clockwise or counter-clockwise from the starting angle? | int | .rotation | Appearance | | Section Colors | The colors to use for the pie wedge fills. | Color[] | .sectionColors | Appearance | | Selected Wedge | The currently selected wedge. (Read only. Usable in bindings and scripting.) | String | .selectedData | Uncategorized | | Selection Enabled? | If true, the user will be able to select wedges on the chart. The selected wedge will be highlighted, and the "selectedData" property will reflect it. | boolean | .selectionEnabled | Behavior | | Selection Highlight Color | The color of the selection highlight. | Color | .selectionHighlightColor | Appearance | | Selection Highlight Width | The line width of the selection highlight. | float | .selectionHighlightWidth | Appearance | | Starting Angle | The start angle to draw the pie wedges. | int | .startAngle | Appearance | | Style | Style of pie chart, standard, 3D, or ring. | int | .style | Appearance | | Title Font | The font for the chart's title. | Font | .titleFont | Appearance | | Tooltip Format | Formatting String. '{0}' is the wedge name, '{1}' is the value, '{2}' is the percent. | String | .tooltipFormat | Appearance | | Tooltips? | Should tooltips be displayed when the mouse hovers over sections? | boolean | .tooltips | Behavior | | Visible | If disabled, the component will be hidden. | boolean | .visible | Common | ## Deprecated Properties The property below is deprecated, and should not be used. | Name | Description | Property Type | Scripting | Category | |---|---|---|---|---| | 3D? | Enables 3D rendering. Deprecated. Use Style property instead. | boolean | .threeDimensional | Appearance | ## Scripting ### Scripting Functions This component does not have scripting functions associated with it. ### Extension Functions This component does not have extension functions associated with it. ### Event Handlers Event handlers allow you to run a script based off specific triggers. See the full list of available event handlers on the [Component Events](scripting\scripting-in-ignition\component-and-window-scripting\component-events.md) page ## Customizers + [Vision Component Customizers](visualization-and-dashboards\understanding-components\component-customizers\component-customizers.md) ## Examples ```py title="Code Snippet" #The following code will print named and value of the selected wedge to the console. #Alternatively, this can be used to write to a custom property of a table that is used to create the 'Where' clause of a SQL query that populates a table. selectedWedge = event.source.selectedData print selectedWedge ```
