--- title: "Equipment Schedule Scripting" --- # Equipment Schedule Scripting > * Parameters > * Component **self** - A reference to the component that is invoking this function. ## Scripting Functions This component does not have scripting functions associated with it. ## Extension Functions ### onBackgroundDragged * Description * Called when the user drags a segment on the schedule background. * int **itemID** - The ID of the equipment item of the row where the user dragged. * Date **startDate** - The datetime corresponding to where the user started dragging. * Date **endDate** - The datetime corresponding to where the user ended dragging. * Event Object **event** - The mouse event. * Return * Nothing * Scope * Client ### onEventClicked * Description * Called when the user clicks on a scheduled event. Use event.clickCount to detect double clicks. * Parameters * Component **self** - A reference to the component that is invoking this function. * int **itemID** - The ID of the equipment item of the event that was clicked on. * int **eventId** - The ID of the event that was clicked on. * Event Object **event** - The mouse event. * Return * Nothing * Scope * Client ### onEventDropped * Description * Called when the user drags and drops a scheduled event. It is up to this script to actually alter the underlying data to reflect the schedule change. * Parameters * Component **self** - A reference to the component that is invoking this function. * int **eventId** - The ID of the scheduled event that was moved. * int **oldItemId** - The ID of the item this event was originally correlated against. * int **newItemId** - The ID of the item whose schedule the event was dropped on. * Date **oldStartDate** - The original starting datetime of the event. * Date **newStartDate** - The new starting datetime of the event. * Date **newEndDate** - The new ending datetime of the event. * Return * Nothing * Scope * Client ### onEventPopupTrigger * Description * Called when the user right-clicks on a scheduled event. This would be the appropriate time to create and display a popup menu. * Parameters * Component **self** - A reference to the component that is invoking this function. * int **itemId** - The ID of the equipment item of the event that was right-clicked on. * int **eventId** - The ID of the event that was right-clicked on. * Event Object **event** - The mouse event that caused the popup trigger. * Return * Nothing * Scope * Client ### onEventResized * Description * Called when the user drags the edge of an event to resize its time span. It is up to this script to actually alter the underlying data to reflect the schedule change. * Parameters * Component **self** - A reference to the component that is invoking this function. * int **eventId** - The ID of the scheduled event that was resized. * int **itemId** - The ID of the item this event is correlated against. * Date **oldStartDate** - The original starting datetime of the event. * Date **oldEndDate** - The original ending datetime of the event. * Date **newStartDate** - The new starting datetime of the event. * Date **newEndDate** - The new ending datetime of the event. * Return * Nothing * Scope * Client ### onPopupTrigger * Description * Called when the user right-clicks outside of an event. This would be the appropriate time to create and display a popup menu. * Parameters * Component **self** - A reference to the component that is invoking this function. * int **itemId** - The item ID of the equipment line that was clicked on (if any). * Event Object **event** - The mouse event that caused the popup trigger. * Return * Nothing * Scope * Client
