--- title: "Easy Chart" description: "This component is used to make powerful and runtime-configurable time-series charts." --- # Easy Chart > This component is used to make powerful and runtime-configurable time-series charts. ![An Easy Chart as it appears when first dropped on a window, with no pens configured yet. The empty plot area is surrounded by the chart's automatic runtime controls: zoom in, print, and save icons down the right side, a date range selector reading "5/29/19 9:25 AM - 5/29/19 9:35 AM" below the plot, a draggable time-range slider spanning 8:00 AM to 9:30 AM, and an Apply button.](easy-chart.png) **Component Palette Icon:** ![Easy Chart component palette icon](easy1-icon.png) ## Description This component is used to make powerful and runtime-configurable time-series charts. It is configured by defining a set of pens and axes. Each pen represents a series of data. Pens can be many different styles, such as line, area, bar, and shape. This chart automatically creates controls for picking the time range and for hiding or displaying pens. ### Features * Easy configuration * User-selectable set of pens * Automatic time-selection controls * SQL Query and/or SQLTags Historian data sources * Automatic SPC and calculated pen support * Zoom, Pan, X-Trace modes * Any number of Y-axes and subplots * Realtime or Historical ### Pens There are three kinds of pens in the Easy Chart: 1. Tag Historian Pens. These pens pull their data from the [Historian](historian/historian.md) system. 2. Database Pens. These pens will automatically create SQL SELECT queries to pull data from a database table. Typically, this is a table that is the target of a [Historical Transaction Group](sql-bridge-transaction-groups/understanding-transaction-groups/understanding-transaction-groups.md). 3. Calculated Pens. These pens display a calculated dataset based off another pen, such as a moving average or an SPC function such as the UCL (Upper Control Limit). ### Modes: Realtime vs Historical The Easy Chart can operate in 3 different modes. These modes affect the range of data that is displayed, the controls the user is shown, and whether or not the chart polls for data. 1. Historical Mode. In this mode, the user is shown a [Date Range](appendix/components/calendars/date-range/date-range.md) component to pick the range of data to fetch and display. The initial values of this component are set through properties on the chart. In historical mode, the chart does not poll. 2. Realtime Mode. In this mode, the user is given the opportunity to pick the amount of time in the past to display. For example, the last 5 minutes or the last 2 hours. The chart will poll at a rate according to the Poll Rate parameter. 3. Manual Mode. In this mode, the chart will use the values if its Start Date and End Date parameters to govern what data is displayed. Polling is controlled by having the Poll Rate at zero (polling off) or greater than zero. ### Basic Chart Configuration The Easy Chart has many properties, like other components, that control its behavior. Things like its Mode, Polling Rate, etc are configured via the properties. All of the setup for adding pens, axes, subplots, etc is its [Customizer](visualization-and-dashboards/understanding-components/component-customizers/component-customizers.md). You can also drag and drop Historian-enabled tags onto the chart directly in the Designer to add those tags as chart pens. #### Y-Axes The easy chart supports any number of Y-axes. To add an axis, go to the Axes tab of the chart customizer. When adding an axis, you get a number of options such as the type (numeric or logarithmic), label, color, autorange vs fixed range, and auto-ticks vs fixed ticks. You can also modify the position of the axis, but note that by default the Chart's Auto Axis Positioning property is enabled, which means that the chart will balance the axes automatically between left and right depending on demand. As pens are turned on and off by the user, only the axes that are used by visible pens are shown. After you add your axes, you edit any pens that you want to use your new axes. Simply choose the new axis in the axis dropdown of the pen editing window. #### Subplots The Subplots feature lets you break up the chart's plot area into multiple distinct subplots that share the X axis, but have their own Y axes. This is often useful for digital data, as shown in the screenshot above. By default the chart has 1 subplot (the main plot). To add a new subplot, simply hit the add button in the Subplots tab of the chart customizer. Subplots have relatively few options. The Weight option determines how much room the subplot gets relative to the other subplots. For example, in the screenshot above subplot #1's weight is 5, and subplot #2's weight is 1, leading to a 5-to-1 distribution of space. Just like axes, once you add your subplots you should go back to your pens and modify you pens' subplot property for any pens you want to appear on the subplot. #### Pen Groups You can put your pens in groups to break up the pens into some logical separation. For instance, in the screenshot above there are three pen groups: C1, C2, and Valves. The group name is used as the titled border for the pens' grouping container. Groups also have another purpose, but it is more advanced and most people won't have to worry about it. For more, read the Dynamic Pens section below. ### Advanced Configuration #### Dynamic Pens In is often the case that you'll want to make one chart window that services many similar pieces of equipment. For instance, if you have 30 tanks and they all have the same datapoints, you want to be able to use one window for all 30 of them and simply pass the tank number into the chart window as a parameter. There are actually a number of ways to accomplish this, each method suitable for different scenarios. Database pens have 2 ways to be made dynamic. The first is the Chart's Where Clause property. This is a snippet of SQL where clause syntax, like "machine_num = 28" that will be included for alldatabase pens in their queries. The second is to use a dynamic group. Any group can be made a dynamic group in the customizer. For each dynamic group, the easy chart will get a special dynamic property associated with that group. That property is another snippet of SQL where clause that will be applied to all database pens in that group. The other way to make your pens (and anything else about the chart) dynamic at runtime is to use dynamic configuration. Read on... #### Dynamic Configuration The Easy Chart is not just meant to be easy to configure, but also very powerful. In particular, there is an emphasis on the ability to make any configuration change dynamically in a client - not just statically in the Designer. While a bit of scripting or clever property binding may be required, the technique is very powerful. This is achieved by storing all of the settings that you alter in the customizer in a set of expert-level dataset properties. So altering the datasets alters the chart configuration. You can inspect these various datasets, which hold the pens, axes, and subplot information, to see their format. They all look up information by column name (case-insensitive). So, if you have pen configuration stored in a database, you can bind an indirect SQL Query binding to alter the chart's pen set at runtime. ## Properties | Name | Description | Property Type | Scripting | Category | |---|---|---|----|---| | 3D X Offset | The offset to use in the x direction for the '3D Line' pen style. | int | .xOffset3D | Pen Style Options | | 3D Y Offset | The offset to use in the y direction for the '3D Line' pen style. | int | .yOffset3D | Pen Style Options | | Allow Color Changes | If true, pen colors can be set to different values. | boolean | .allowColorChanges | Behavior | | Allow Tag History Interpolation | If enabled and the query mode is not raw, the data will be interpolated for time spans with no data available. | boolean | tagHistoryAllowInterpolation | Tag History | | Antialias | Draw with antialias on? Makes text smoother. | boolean | .antialias | Appearance | | Auto Apply | If true, user changes to pen visibility will occur immediately. | boolean | .autoApply | Behavior | | Auto Axis Positioning | If true, axes alternate automatically between left and right, rather than being placed explicitly. | boolean | .autoPositionAxes | Behavior | | Auto Color List | The list of colors to use if auto pen coloring is enabled. | Color[] | .autoColorList | Behavior | | Auto Pen Coloring | If true, pens are assigned different colors automatically. | boolean | .autoColorPens | Behavior | | Axes | This Dataset defines all axes that can be used by the pens. | Dataset | .axes | Chart Configuration | | Axis Font | The font for axis labels. | Font | .axisLabelFont | Appearance | | Background Color | The background color of the component. | Color | .background | Appearance | | Bar Margin | The margin to use for the 'Bar' pen style. | double | .barMargin | Pen Style Options | | Border | The border surrounding this component. NOTE that the border is unaffected by rotation. | Border | .border | Appearance | | Box Fill | For historical-mode date range. The fill color for the selection box. | Color | .boxFill | Historical Range | | Button Size | The size of the utility button icons. | int | .utilityButtonSize | Utility Buttons | | Bypass Tag History Cache | If true, tag history queries will not use the client history cache. | boolean | .tagHistoryBypassCache | Tag History | | Calculated Pens | This Dataset defines the calculated pens for the chart. | Dataset | .calcPens | Chart Configuration | | Chart Border | The border for the chart itself. | Border | .chartBorder | Appearance | | Chart Mode | Affects the mode that the chart operates in; Manual Mode, Historical Mode, Realtime Mode.0 - Manual1 - Historical2 - Realtime | int | .chartMode | Behavior | | Chart Title | Sets an optional title to be displayed above the chart. | String | .title | Appearance | | Cursor | The mouse cursor to use when hovering over this component. | int | .cursorCode | Common | | DB Pens | This Dataset defines all of the database pens for the chart. | Dataset | .pens | Chart Configuration | | Date Editor Background | The background color for the date editor. | Color | .editorBackgroundColor | Appearance | | Date Editor Foreground | The foreground color for the date editor. | Color | .editorForegroundColor | Appearance | | Date Range | Affects the position of the date range control. | int | .dateRangeLocation | Layout | | Date Range Border | The border for the date range control, if visible. | Border | .dateRangeBorder | Appearance | | Date Style | The style to display dates in. For international support. | int | .dateStyle | Historical Range | | Digital Gap | The size of the gap to use between digital pens. | double | .digitalGap | Pen Style Options | | Empty Group Name | The group name to use for pens that are not in a pen group. | String | .emptyGroupName | Behavior | | End Date | For manual-mode. The end date to use for selecting pen data | Date | .endDate | Data | | Font | Font of text on this component. | Font | .font | Appearance | | Foreground Color | The foreground color of the component. | Color | .foreground | Appearance | | Gap Threshold | The relative threshold to use for determining continuity breaks for the 'Discontinous Line' pen style. | double | .gapThreshold | Pen Style Options | | Gridline Color | The color of the gridlines. | Color | .gridlineColor | Appearance | | Gridline Dash Pattern | Enter a string of comma-delimited numbers which indicate the stroke pattern for a dashed line. For instance, "3,5" means three pixels on, five pixels off. | String | .gridlineDashPattern | Appearance | | Gridline Width | The width (thickness) of the gridlines. | float | .gridlineWidth | Appearance | | Group Pens | If true, pens will be grouped by their group name. | boolean | .penGrouping | Behavior | | High Density Color | For historical-mode date range. The color used to indicate high data density. | Color | .highDensityColor | Historical Range | | Horiz Gap | The horizontal spacing to use for the pen checkboxes. | int | .hGap | Layout | | Ignore Bad Quality Data | If true, causes the system to ignore any bad quality data. | boolean | tagHistoryIgnoreBadData | Tag History | | Invert Time Axis | If true, the time axis values will increase from the right to left or from top to bottom depending on the Plot Orientation. | boolean | .invertTimeAxis | Layout | | Legend | Where the legend should appear, if any. | int | .legend | Layout | | Max Selection | For historical-mode date range. The maximum size of the selected date range. | String | .maxSelectionSize | Historical Range | | Maximize Plot | If true, displays maximized plot. | boolean | .currentlyMaximized | Layout | | Mouseover Text | The text that is displayed in the tooltip which pops up on mouseover of this component. | String | .toolTipText | Common | | Name | The name of this component. | String | .name | Common | | Outer Range End | For historical-mode date range. The end date for the outer range. | Date | .outerRangeEnd | Historical Range | | Outer Range Start | For historical-mode date range. The start date for the outer range. | Date | .outerRangeStart | Historical Range | | Pen Control Border | The border for the pen control panel, if visible. | Border | .penBorder | Appearance | | Pen Control Mode | The style in which the pen control panel alters the chart configuration. In heavyweight mode, unchecked pens are not queried, so checking and unchecking pens refreshes the chart. In lightweight mode, all pens are constantly queried, so checking and unchecking pens is quick. | int | .penControlMode | Behavior | | Pen Control? | Controls whether or not end-users can turn on and off pens. | boolean | .allowPenManipulation | Behavior | | Plot Background | The background color for all plots, unless they override it. | Color | .plotBackground | Appearance | | Plot Orientation | The plot orientation for all plots. | int | .plotOrientation | Layout | | Plot Outline | The color to use for the plot outline. | Color | .plotOutlineColor | Appearance | | Poll Rate | The rate (in milliseconds) at which this chart's queries poll. Historical charts don't use this property. | int | .pollRate | Behavior | | Properties Loading | The number of properties currently being loaded. (Read only. Usable in bindings and scripting.) | int | .propertiesLoading | Uncategorized | | Realtime Text | For realtime-mode date range. The text to display on the realtime date control. | String | .rtLabel | Realtime Range | | Selected X Value | The selected domain axis value for X-Trace and Mark modes. (Read only. Usable in bindings and scripting.) | String | .selectedXValue | Uncategorized | | Selection Highlight | For historical-mode date range. The focus highlight color for the selection box. | Color | .selectionHighlight | Historical Range | | Show Density | For historical-mode date range. If true, a data density histogram will be shown in the date range. | boolean | .showHistogram | Historical Range | | Show Loading | If true, an animated indicator will be shown when data is loading. | boolean | .showLoading | Behavior | | Show Maximize Button? | If true, a small maximize button will be displayed next to the chart. | boolean | .showMaximize | Utility Buttons | | Show Popup? | If true, a popup menu will be shown on right-click that allows the user to change mode, print, save, etc. | boolean | .showPopup | Behavior | | Show Print Button? | If true, a small print button will be displayed next to the chart.. | boolean | .showPrint | Utility Buttons | | Show Save Button? | If true, a small save button will be displayed next to the chart. | boolean | .showSave | Utility Buttons | | Show Tooltips? | If true, tooltips showing point values will be displayed on the chart. | boolean | .tooltips | Behavior | | Show Warnings | If true, warnings generated during chart configuration will be printed to the console. | boolean | .showWarnings | Behavior | | Sort Pens | If true, pens visibility checkboxes will be sorted. | boolean | .alphabetizePens | Layout | | Start Date | For manual-mode. The start date to use for selecting pen data. | Date | .startDate | Data | | Startup Range | For historical-mode date range. If startup mode is Automatic, this will be the starting range of time available for selection. | String | .startupRange | Historical Range | | Startup Selection | For historical-mode date range. If startup mode is Automatic, this will be the starting selected range. | String | .startupSelection | Historical Range | | Subplot Gap | The gap between subplots. | double | .subplotGap | Layout | | Subplots | This Dataset defines all subplots' relative size and color. | Dataset | .subplots | Chart Configuration | | Tag History Resolution | The number of datapoints to request for tag history pens. -1 means raw data, 0 means automatic, which uses the width of the chart. | int | .tagHistoryResolution | Tag History | | Tag History Resolution Mode | The mode used for the number of requested points. Fixed will use the Tag History Resolution Size, Natural will return a value per scanclass execution, Chart Width will be based on the actual width of the chart component, and Raw will be the raw data. | int | tagHistoryResolutionMode | Tag History | | Tag Pens | This Dataset defines all of the Tag History pens for the chart. | Dataset | .tagPens | Chart Configuration | | Tick Density | For historical-mode date range. This is multiplied by the width to determine the current ideal tick unit. | float | .tickDensity | Historical Range | | Tick Font | The font for tick labels. | Font | .axisTickLabelFont | Appearance | | Time Style | The style to display times of day. For international support. | int | .timeStyle | Historical Range | | Title Font | The font for the optional chart title. | Font | .titleFont | Appearance | | Today Color | For historical-mode date range. The color of the "Today Arrow" indicator. | Color | .todayIndicatorColor | Historical Range | | Total Datapoints | The number of datapoints being displayed by the graph. (Read only. Usable in bindings and scripting.) | int | .datapoints | Uncategorized | | Track Margin | For historical-mode date range. The amount of room on either side of the slider track. May need adjusting of default font is changed. | int | .trackMargin | Historical Range | | Unit | For realtime-mode date range. The selected unit of the realtime date control. | int | .unit | Realtime Range | | Unit Count | For realtime-mode date range. The number of units back to display. | int | .unitCount | Realtime Range | | Validate Scan Class Executions | Causes the tag history query to verify the scan class execution records, generating bad data for the time periods where the scanclasses did not execute. | boolean | tagHistoryValidateScanclass | Tag History | | Vert Gap | The vertical spacing to use for the pen checkboxes. | int | .vGap | Layout | | Visible | If disabled, the component will be hidden. | boolean | .visible | Common | | Where Clause | A snippet of where clause that will be applied to all pens, like "TankNum = 2". | String | .globalWhereClause | Data | | X Axis AutoRange? | If true, the X axis will automatically fit the range of available data, if false, it will display a fixed range based on the start date and end date. | boolean | .xAxisAutoRange | Behavior | | X Axis Label | The label shown on the X Axis (time axis). | String | .xAxisLabel | Appearance | | X Axis Margin | A margin for the upper and lower ends of the x axis, expressed as a percentage of the total range. | double | .xAxisMargin | Behavior | | X Axis Visible | Should the x-axis be displayed? | boolean | .xAxisVisible | Appearance | | X-Trace Large Number Format | The large decimal format for the x-trace value in the Easy Chart. | String | .xTraceLargeNumberFormat | Appearance | | X-Trace Number Format Threshold | If the magnitude of the to-be-formatted value is below this threshold, then the X-Trace Small Number Format will be used. | double | .xTraceNumberFormatThreshold | Appearance | | X-Trace Small Number Format | The small decimal format for the x-trace value in the Easy Chart. | String | .xTraceSmallNumberFormat | Appearance | | X-Trace Track Mouse | If set enabled, and the chart is set to X-Trace mode, the X-Trace will auto track the mouse position while the cursor is over the component. This is particularly useful when displaying the Easy Chart on a touchscreen. | boolean | xTraceTrackMouse | Appearance | ## Scripting See the [Easy Chart Scripting Functions](easy-chart-scripting-functions.md) page for the full list of scripting functions available for this component. ### Event Handlers Event handlers allow you to run a script based off specific triggers. See the full list of available event handlers on the [Component Events](scripting\scripting-in-ignition\component-and-window-scripting\component-events.md) page ## Customizers Refer to the [Easy Chart Customizer](easy-chart-customizer.md) and the [Easy Chart](historian/using-the-easy-chart/using-the-easy-chart.md) sections of the manual for examples and tutorials on how to use the Easy Chart Customizer. With the customizer, you can set up: * [Axes](historian/using-the-easy-chart/easy-chart-axes/easy-chart-axes.md) * [Subplots](historian/using-the-easy-chart/easy-chart-subplots/easy-chart-subplots.md) * [Pen Groups](historian/using-the-easy-chart/easy-chart-pen-names-and-groups/easy-chart-pen-names-and-groups.md) * [Pen Display](historian/using-the-easy-chart/easy-chart-pen-renderer/easy-chart-pen-renderer.md) * [Offsets](historian/using-the-easy-chart/easy-chart-digital-offset/easy-chart-digital-offset.md) * [Calculated Pens](historian/using-the-easy-chart/easy-chart-calculated-pens/easy-chart-calculated-pens.md) * [Ad-Hoc Charting](historian/using-the-easy-chart/ad-hoc-charting/ad-hoc-charting.md) * [Indirection](historian/using-the-easy-chart/indirect-easy-chart/indirect-easy-chart.md)
