--- title: "Chart Customizer" description: "The Chart component, also known as the Classic Chart, can be used to make almost any kind of chart. It provides a flexible way to display XY charts using a host of built-in properties. All you need to do to create a chart is add datasets, fill them in with data, configure a property binding, and setup the chart properties using the customizer." --- # Chart Customizer > The Chart component, also known as the Classic Chart, can be used to make almost any kind of chart. It provides a flexible way to display XY charts using a host of built-in properties. All you need to do to create a chart is add datasets, fill them in with data, configure a property binding, and setup the chart properties using the customizer. ![The Chart Customizer window with its five tabs across the top: Datasets, X-Axes, Y-Axes, Dataset Properties, and Plot Properties. The X-Axes tab is open, listing Date and Default X Axis in the Axes panel on the left with Date selected, and a Properties table on the right showing that axis' settings, including Axis Visible, Axis Label, Axis Label Angle, Axis Label Color, Axis Label Font, Tick Labels Visible, and Tick Label Color. OK and Cancel buttons sit at the bottom.](chart-customizer.png) ## Description The [Chart component](appendix/components/charts/chart/chart.md), also known as the Classic Chart, can be used to make almost any kind of chart. It provides a flexible way to display XY charts using a host of built-in properties. All you need to do to create a chart is add datasets, fill them in with data, configure a property binding, and setup the chart properties using the customizer. ## Customizer The Chart component has its own special customizer called the Chart Customizer. When you open the customizer, you'll notice five tabs at the top: Dataset, X-Axes, Y-Axes, Dataset Properties, and Plot Properties. Each tab has its own set of properties and defaults. To get started, first add your dataset(s) and any additional XY axes using the appropriate tabs in the customizer. You can configure additional properties for each dataset, like what axes the data maps to, as well as select from a host of visual styles. There are six types of axes to choose from when configuring a chart, each having its own list of properties: Number Axis, Date Axis, Category Axis, Logarithmic Axis, Elapsed Axis, and Symbols Axis. Most of the X and Y axes properties are used in the customizer, and some properties are specific to the axis type and have their own unique properties The customizer already has some default styles in place to help you get started, but you can modify these default settings to your own style using the XY properties, Axes Type, Renderer and Plot styles. If you don't like one style, try another. Shown below is each tab in the Chart Customizer with all its properties, description, and what axes type it supports. Note: Not all properties are available for all axes type charts. ### Datasets Tab The Dataset tab is where you set up, add, and remove datasets. ![The Datasets tab of the Chart Customizer, showing a table with Name, Type, and Description columns and one row: a dataset named Data of type Dataset, described as "Default DataSet". Plus and trash-can icons for adding and deleting datasets sit to the right of the table.](dataset-tab.png) | Property | Description | |----------|-------------| | Data | Default dataset property. | | ![Plus icon](add.png) Add | Adds a new dataset. Click the plus icon a new row will be added. Enter the dataset Name and Description. | | ![Trash can icon](delete.png) Delete | Deletes an existing dataset. Click the Delete icon to delete an existing dataset. | | Name | Name of the dataset. Double click in the field to rename the dataset. | | Type | Default type is "Dataset." | | Description | Describes the dataset. | ### X-Axes Tab The X-Axes tab is where X-Axis properties are configured. You can also add and delete X axes here. ![The X-Axes tab of the Chart Customizer, expanded to show the full Properties table. The Axes panel on the left lists Date and Default X Axis, with green plus and red delete icons beneath it. The Properties table on the right lists every X-axis setting with its current value, from Axis Visible, Axis Label, and the label and tick font and color settings, through Axis Position, Auto Range and its bounds and margins, the Negative and Positive Arrow and Vertical Tick Labels checkboxes, and the date-specific Date Style, Time Style, Max Date, Min Date, and Display Date In Title settings.](x-axes-tab.png) | Property | Description | Support Axes Types | |--- |--- |--- | | ![Green plus icon](add-axis.png) | Add X axis. When you add an X axis, you can select from one of the following axis types: Number, Date, Category, Logarithmic, Elapsed, and Symbol.Click the green plus icon, select an Axis Type, enter an Axis Name, and click OK. ![The Add New Axis dialog, with an Axis Name field set to "Date", an Axis Type dropdown set to "Date Axis", and OK and Cancel buttons.](x-axes-type.png) | All | | ![Red X delete icon](delete-axis.png) | Delete an existing axis. Select the axis, and click the Delete icon. | All | | Axis Visible | If false, the axis will be hidden. | All | | Axis Label | Name of the axis. | All | | Axis Label Angle | Angle of the value on the axis label. | All | | Axis Label Color | Color of axis label. | All | | Axis Label Font | Font type and size of text on axis label. | All | | Tick Labels Visible | If false, the tick labels will be hidden. | All | | Tick Label Color | Color of tick labels. | All | | Tick Label Font | Font type and size of text on tick labels. | All | | Tick Marks Visible | If false, the tick marks will be hidden. | All | | Tick Mark Color | Color of tick marks. | All | | Tick Mark Inside Length | Length of tick marks inside the chart. | All | | Tick Mark Outside Length | Length of tick marks outside the chart. | All | | Axis Position | Depends on the axis selected. X-axis label alternates between top and bottom. Y-axis label alternates between left and right. You many need to change both X and Y axis properties to get your intended axis position. | All | | Auto Range | If true, the value axis range will be determined automatically. If false, the specified Lower and Upper bounds will be used. | All | | Auto Range Min Size | If true, the minimum value range is used. | Date, Number, Logarithmic, Symbol, Elapsed | | Fixed Auto Range | Sets an axis up for dynamic graphs. | Date, Number, Logarithmic, Symbol, Elapsed | | Lower Bound | Lower bound value. Used only when Auto Range is false. | Date, Number, Logarithmic, Symbol, Elapsed | | Upper Bound | Upper bound value. Used only when Auto Range is false. | Date, Number, Logarithmic, Symbol, Elapsed | | Lower Margin (% of range) | Lower margin represented as a percentage. Used only when Auto Range is true. | Date, Number, Logarithmic, Symbol, Elapsed | | Upper Margin (% of range) | Upper margin represented as a percentage. Used only when the Auto Range is true. | Date, Number, Logarithmic, Symbol, Elapsed | | Negative Arrow | If true, negative arrow is visible. | Date, Number, Logarithmic, Symbol, Elapsed | | Positive Arrow | If true, positive arrow is visible. | Date, Number, Logarithmic, Symbol, Elapsed | | Vertical Tick Labels | Vertical orientation for tick labels. | Date, Number, Logarithmic, Symbol, Elapsed | | Auto Range Includes Zero | If true, the range includes a zero. | Date, Number, Logarithmic, Symbol, Elapsed | | Auto Range Sticky Zero | If true, the zero is on both the XY axes. | Date, Number, Logarithmic, Symbol, Elapsed | | Number Format Override | Overwrites the current number format. | Date, Number, Logarithmic, Symbol | | Date Style | The style of the date displayed on the axis. | Date | | Time Style | The style of the time displayed on the axis. | Date | | Max Date | Max value in a series of dates. | Date | | Min Date | Min value in a series of dates. | Date | | Display Date in Title | If true, the date will be displayed in the title when the range is zoomed into the hour range. | Date | | Label Angle | The angle for the value axis labels. | Category | | "1e#"-style tick labels | If true, uses scientific notation format (i.e.,1e5, 1e6, etc.,). | Logarithmic | | "10^n"-style tick labels | If true, uses power notation format (i.e., 10 to the "X" power). | Logarithmic | | Symbols String | Sequence of characters such as a literal constant. (i.e., On,Off,Auto) | Symbols | | Grid Bands Visible | If true, grid bands will be hidden. | Symbols | | Grid Bands Color | Color of grid bands. | Symbols | | Grid Bands Alternate Color | Backup color of grid bands. | Symbols | | Format String | Specified sequence of characters. | Elapsed | ### Y-Axes Tab The Y-Axes tab is where Y-Axis properties are configured. You can also add and delete Y axes here. ![The Y-Axes tab of the Chart Customizer, expanded to show the full Properties table. The Axes panel on the left lists a single Default Y Axis, with green plus and red delete icons beneath it. The Properties table on the right lists every Y-axis setting with its current value, from Axis Visible and an Axis Label of "Value" through the label and tick font and color settings, Axis Position, Auto Range and its bounds and margins, the Negative and Positive Arrow and Vertical Tick Labels checkboxes, Auto Range Includes Zero, Auto Range Sticky Zero, and Number Format Override.](y-axes-tab.png) | Property | Description | Support Axes Types | |--- |--- |--- | | ![Green plus icon](add-axis.png) | Add axis. When you add a Y axis, you can select from one of the following axis types: Number, Date, Category, Logarithmic, Elapsed, and Symbol.Click the green plus icon, select an Axis Type, enter an Axis Name, and click OK. ![The Add New Axis dialog, with an Axis Name field set to "Symbol", an Axis Type dropdown set to "Symbol Axis", and OK and Cancel buttons.](y-axes-type.png) | All | | ![Red X delete icon](delete-axis.png) | Delete an existing axis. Select an axis, and click the Delete icon. | All | | Axis Visible | If false, the axis will be hidden. | All | | Axis Label | Name of the axis. | All | | Axis Label Angle | Angle of the value on the axis label. | All | | Axis Label Color | Color of axis label. | All | | Axis Label Font | Font type and size of text on axis label. | All | | Tick Labels Visible | If false, the tick labels will be hidden. | All | | Tick Label Color | Color of tick labels. | All | | Tick Label Font | Font type and size of text on tick labels. | All | | Tick Marks Visible | If false, the tick marks will be hidden. | All | | Tick Mark Color | Color of tick marks. | All | | Tick Mark Inside Length | Length of tick marks inside the chart. | All | | Tick Mark Outside Length | Length of tick marks outside the chart. | All | | Axis Position | Depends on the axis selected. X-axis label alternates between top and bottom. Y-axis label alternates between left and right. You many need to change both X and Y axis properties to get your intended axis position. | All | | Auto Range | If true, the value axis range will be determined automatically. If false, the specified Lower and Upper bounds will be used. | All | | Auto Range Min Size | If true, the minimum value range is used. | Date, Number, Logarithmic, Symbol, Elapsed | | Fixed Auto Range | Sets an axis up for dynamic graphs. | Date, Number, Logarithmic, Symbol, Elapsed | | Lower Bound | Lower bound value. Used only when Auto Range is false. | Date, Number, Logarithmic, Symbol, Elapsed | | Upper Bound | Upper bound value. Used only when Auto Range is false. | Date, Number, Logarithmic, Symbol, Elapsed | | Lower Margin (% of range) | Lower margin represented as a percentage. Used only when Auto Range is true. | Date, Number, Logarithmic, Symbol, Elapsed | | Upper Margin (% of range) | Upper margin represented as a percentage. Used only when the Auto Range is true. | Date, Number, Logarithmic, Symbol, Elapsed | | Negative Arrow | If true, negative arrow is visible. | Date, Number, Logarithmic, Symbol, Elapsed | | Positive Arrow | If true, positive arrow is visible. | Date, Number, Logarithmic, Symbol, Elapsed | | Vertical Tick Labels | Vertical orientation for tick labels. | Date, Number, Logarithmic, Symbol, Elapsed | | Auto Range Includes Zero | If true, the range includes a zero. | Date, Number, Logarithmic, Symbol, Elapsed | | Auto Range Sticky Zero | If true, the zero is on both the XY axes. | Date, Number, Logarithmic, Symbol, Elapsed | | Number Format Override | Overwrites the current number format. | Date, Number, Logarithmic, Symbol | | Date Style | The style of the date displayed on the axis. | Date | | Time Style | The style of the time displayed on the axis. | Date | | Max Date | Max value in a series of dates. | Date | | Min Date | Min value in a series of dates. | Date | | Display Date in Title | If true, the date will be displayed in the title when the range is zoomed into the hour range. | Date | | Label Angle | The angle for the value axis labels. | Category | | "1e#"-style tick labels | If true, uses scientific notation format (i.e.,1e5, 1e6, etc.,). | Logarithmic | | "10^n"-style tick labels | If true, uses power notation format (i.e., 10 to the "X" power). | Logarithmic | | Symbols String | Sequence of characters such as a literal constant. (i.e., On,Off,Auto) | Symbols | | Grid Bands Visible | If true, grid bands will be hidden. | Symbols | | Grid Bands Color | Color of grid bands. | Symbols | | Grid Bands Alternate Color | Backup color of grid bands. | Symbols | | Format String | Specified sequence of characters. | Elapsed | ### Dataset Properties Tab The Dataset tab is where you can modify the visual styles of your chart. You can configure your chart with subplots, experiment with different renderer types and property types to change how the data is displayed until you find what best meets your requirements. :::note Not all Renderer properties are available for each axis type. ::: ![The Dataset Properties tab of the Chart Customizer. The Datasets panel on the left lists the Data dataset. The Dataset Properties panel on the right sets X Axis to Date, Y Axis to Default Y Axis, Subplot Number to 1, Enabled checked, and Renderer to XY Line/Shape Renderer. A Dataset Renderer Properties table below it shows Series Colors as an ordered strip of eight numbered color swatches, Type set to Lines Only, Line Size 1.0, an empty Dash Pattern, Fill Shapes checked, and Shape Offset 0.](dataset-properties-tab.png) | Property | Description | Support Axes Types | |--- |--- |--- | | Dataset | Collection of data in tabular form. Data from the dataset drives the chart. | All | | X Axis | Horizontal axis. | All | | Y Axis | Vertical axis. | All | | Subplot Number | Number of plot areas on one chart. | All | | Enabled | If true, the chart is displayed with the selected renderer properties. | All | | Renderer | The visual style of the data presented on the chart. Select from various renderer styles:XY Line/Shape Renderer XY Bar RendererXY Area RendererXY Step RendererXY Step Area RendererXY Dot RendererCategory Line/Shape RendererCategory Bar Renderer | All | | Series Colors | An ordered list of the colors to draw series in. | All | | Type | Type of XY Item Renderer. | All | | Line Size | The thickness of the line. | All | | Dash Pattern | The pattern used for dashed lines. | All | | Fill Shapes | If false, there is only an outline of the shape, no fill color. | All | | Shape Offset | The offset into the standard shape list to start this renderer at. Offset values and respective values are listed below. 0 - Square1 - Circle2 - Upward triangle3 - Diamond4 - Horizontal rectangle5 - Downward triangle6 - Horizontal ellipse7 - Rightward triangle8 - Vertical rectangle9 - Leftward triangle | Offset | | Margin | The percentage by which the bars are trimmed using the XY Bar Renderer. | All | | Shadows | If true, draws shadows under the bars using the XY Bar Renderer. | All | | Outline | If true, draws an outline around the area using the XY Area Renderer. | All | | Draw Lines | If true, lines will be drawn to connect the datapoints using the Category Line/Shape Renderer. | All | | Draw Shapes | If true, shapes will be drawn to connect each datapoint if using the Category Line/Shape Renderer. | All | | Date Style | The style of the date displayed on the axis. | Date | | Time Style | The style of the time displayed on the axis. | Date | | Max Date | Max value in a series of dates. | Date | | Min Date | Min value in a series of dates. | Date | | Display Date in Title | If true, the date will be displayed in the title when the range is zoomed into the hour range. | Date | | Label Angle | The angle for the value axis labels. | Category | | "1e#"-style tick labels | If true, uses scientific notation format (i.e.,1e5, 1e6, etc.,). | Logarithmic | | "10^n"-style tick labels | If true, uses power notation format (i.e., 10 to the "X" power). | Logarithmic | | Symbols String | Sequence of characters such as a literal constant. (i.e., On,Off,Auto) | Symbols | | Grid Bands Visible | If true, grid bands will be hidden. | Symbols | | Grid Bands Color | Color of grid bands. | Symbols | | Grid Bands Alternate Color | Backup color of grid bands. | Symbols | | Format String | Specified sequence of characters. | Elapsed | ### Plot Properties Tab The Plot Properties tab allows you to break up the chart plot area into multiple distinct subplots. ![The Plot Properties tab of the Chart Customizer. A list on the left holds a single entry, Plot 1. The panel on the right shows an unchecked Override Background Color checkbox, a grayed-out Background Color picker, and Plot Weight (Relative) set to 1.](plot-properties-tab.png) | Property | Description | Axes Types Supports | |----------|-------------|--------------------| | Plot | The chart area displaying data. | All | | Override Background Color | If enabled, allows you to change the background color. | All | | Background Color | Background color of the chart. | All | | Plot Weight (Relative) | The chart ratio between subplots. | All | ### References * [Chart](appendix/components/charts/chart/chart.md) * [Component Customizers](visualization-and-dashboards/understanding-components/component-customizers/component-customizers.md) * [Understanding Component Customizers](visualization-and-dashboards/understanding-components/understanding-components.md#component-customizers) ## Axis Type Examples The Chart Customizer has six different axis types to choose from when configuring a chart, each with its own list of properties. :::note Some customizer properties are specific to the axis type and have their own unique properties. Examples of all axis types are shown below along with the property settings used to create each chart. ::: ### Number Axis Chart ![A scatter chart plotting the Process Temp series as blue square markers with no connecting lines. The X axis is a number axis labeled "Number Axis" in red running from 0 to 140, and the Y axis is labeled "Output Temp" in red running from 0 to 60. Tick labels on both axes are green, and a legend below the plot names the Process Temp series.](number-axis.png) #### Binding Type * Tag - Tag History #### Chart Customizer Property Settings **Datasets Tab** | Property Name | Value | |---------------|-------| | Datasets | Data | **X-Axes Tab** | Property Name | Value | |---------------|-------| | Axes | Number | | X Axis Label | Number Axis | | Axis Label Color | Red | | Tick Label Color | Green | **Y-Axes Tab** | Property Name | Value | |---------------|-------| | Axes | Default Y Axis | | Y Axis Label | Output Temp | | Axis Label Color | Red | | Tick Label Color | Green | **Dataset Properties Tab** | Property Name | Value | |---------------|-------| | X Axis | Number | | Y Axis | Default Y Axis | | Renderer | XY Line/Shape Renderer | | Type | Shapes Only | #### Dataset Property Dataset ![The Dataset Viewer window showing the dataset behind the Number Axis chart: two numeric columns, Output Temp and Process Temp, with rows such as 57 and 45, 59 and 45, and 57 and 40.](number-dataset.png) ### Date Axis Chart ![A timeseries chart with a Value Y axis from 0 to 900 and a red-labeled "Date" X axis spanning 9:42 AM to 10:01 AM on Feb 6, 2017. Three sawtooth line series, ramp0 in black, ramp1 in red, and ramp2 in green, repeat across the range, with a legend below the plot. Beneath the chart are a date range selector reading "2/6/17 9:42 AM - 2/6/17 10:01 AM" and a time-range slider spanning 4 AM to 12 PM.](date-axis.png) #### Chart Customizer Property Settings **Datasets Tab** | Property Name | Value | |---------------|-------| | Datasets | Data | **X-Axes Tab** | Property Name | Value | |---------------|-------| | Axes | Date | | Axis Label | Date | | Axis Label Color | Red | **Y-Axes Tab** | Property Name | Value | |---------------|-------| | Axes | Default Y Axis | | Axis Label | Value | | Axis Label Color | Red | **Dataset Properties Tab** | Property Name | Value | |---------------|-------| | Datasets | Data | | X Axis | Date | | Y Axis | Default Y Axis | | Renderer | XY Line/Shape Renderer | | Type | Lines Only | #### Dataset Property Dataset ![The Dataset Viewer window showing the dataset behind the Date Axis chart: a t_stamp column of timestamps at ten-second intervals starting at 02/03/2017 11:00:00, followed by numeric ramp0, ramp1, and ramp2 columns.](date-axis-dataset.png) ### Category Axis Chart ![A category bar chart with a Value Y axis from 0 to 65 and a blue-labeled "Category Axis" X axis holding two categories, Process Temp and Output Temp. Each category shows four bars, one per quarter: Q1 in blue, Q2 in red, Q3 in green, and Q4 in yellow. The Process Temp bars sit around 60 to 65 and the Output Temp bars around 41 to 45. A color-coded legend appears below the plot.](category-chart.png) **Behavior** | Property | Value | |---|---| | Chart Type | Category | #### Chart Customizer Property Settings **Datasets Tab** | Property Name | Value | |---------------|-------| | Datasets | Data | **X-Axes Tab** | Property Name | Value | |---------------|-------| | Axes | Category | | Axis Label | Category Axis | | Axis Label Color | Blue | **Y-Axes Tab** | Property Name | Value | |---------------|-------| | Axes | Default Y Axis | | Axis Label | Value | | Axis Label Color | Blue | **Dataset Properties Tab** | Property Name | Value | |---------------|-------| | Datasets | Data | | X Axis | Category | | Y Axis | Default Y Axis | | Renderer | Category Bar Renderer | | Type | Bar | #### Dataset Property Dataset ![The Dataset Viewer window showing the dataset behind the Category Axis chart: a Month column holding the category names Q1 through Q4, plus Process Temp and Output Temp value columns with rows 64 and 45, 60 and 43, 65 and 41, and 60 and 41.](category-dataset.png) ### Logarithmic Axis Chart ![A line chart with a Value Y axis from 0 to 45 and a red-labeled "Logarithmic Axis" X axis whose tick labels step by powers of ten from 100 to 1000000. The single Output Temp series rises gently from about 42 to 47 across the log scale, and a legend below the plot names the series.](log-axis.png) #### Chart Customizer Property Settings **Datasets Tab** | Property Name | Value | |---------------|-------| | Datasets | Data | **X-Axes Tab** | Property Name | Value | |---------------|-------| | Axes | Logarithmic | | Axis Label | Logarithmic Axis | | Axis Label Color | Red | **Y-Axes Tab** | Property Name | Value | |---------------|-------| | Axes | Default Y Axis | | Axis Label | Value | | Axis Label Color | Red | **Dataset Properties Tab** | Property Name | Value | |---------------|-------| | Datasets | Data | | X Axis | Logarithmic | | Y Axis | Default Y Axis | | Renderer | XY Line/Shape Renderer | | Type | Lines Only | #### Dataset Property Dataset ![The Dataset Viewer window showing the dataset behind the Logarithmic Axis chart: a Process Temp column with the widely spaced values 60, 65, 670, and 636300, and an Output Temp column with the values 44, 42, 44, and 47.](log-dataset.png) ### Symbols Axis Chart ![A line chart whose Y axis is a symbol axis labeled "State" in green, with tick labels reading On, Off, and Auto in place of numbers. The X axis is labeled "Symbol Axis" in green and spans 6:30 AM to 9:00 AM on Jan 26, 2017. Two thick line series, Machine A in blue and Machine B in red, step between the three named states, with a legend below the plot.](symbol-chart.png) #### Chart Customizer Property Settings **Datasets Tab** | Property Name | Value | |---------------|-------| | Datasets | Data | **X-Axes Tab** | Property Name | Value | |---------------|-------| | Axes | Default Axis | | Axis Label | Symbol Axis | | Axis Label Color | Green | **Y-Axes Tab** | Property Name | Value | |---------------|-------| | Axes | Symbol | | Axis Label | State | | Axis Label Color | Green | | Symbols String | On,Off,Auto | **Dataset Properties Tab** | Property Name | Value | |---------------|-------| | Datasets | Data | | X Axis | Default X Axis | | Y Axis | Symbol | | Renderer | XY Line/Shape Renderer | | Type | Lines Only | | Line Size | 3 | #### Dataset Property Dataset ![The Dataset Viewer window showing the dataset behind the Symbols Axis chart: a t_stamp column with four hourly timestamps from 01/26/2017 06:09:29 to 09:09:29, and Machine A and Machine B columns holding the state numbers 0, 1, and 2 that the symbol axis maps to On, Off, and Auto.](symbol-dataset.png) ### Elapsed Time Axis Chart ![A line chart with a Value Y axis from 0 to 50 and a red-labeled "Timestamp" X axis whose green tick labels show elapsed time rather than clock time, running from 00:00:00 to 00:02:00 in thirty-second steps. A single sine2 series oscillates through several full cycles, with a legend below the plot. Beneath the chart are a date range selector reading "2/13/17 3:50 PM - 2/13/17 3:51 PM" and a time-range slider spanning 3:00 PM to 4:30 PM.](elapsed-time-chart.png) #### Binding Type * Database * SQL Query #### Chart Customizer Property Settings **Datasets Tab** | Property Name | Value | |---------------|-------| | Dataset | Data | **X-Axes Tab** | Property Name | Value | |---------------|-------| | Axes | Elapsed Time | | Axis Label | Timestamp | | Axis Label Color | Red | | Tick Label Color | Green | | Upper Bound | 60,000 | | Tick Size (ms) | 30,000 | **Y-Axes Tab** | Property Name | Value | |---------------|-------| | Axes | Default Y Axis | | Axis Label | Value | | Axis Label Color | Red | | Tick Label Color | Green | **Dataset Properties Tab** | Property Name | Value | |---------------|-------| | Datasets | Data | | X Axis | Elapsed | | Y Axis | Default Y Axis | | Renderer | XY Line/Shape Renderer | | Type | Lines Only | #### Dataset Property Dataset ![The Dataset Viewer window showing the dataset behind the Elapsed Time Axis chart: a t_stamp column of elapsed milliseconds counting up from 0 in steps of 1000, and a sine2 column of the corresponding values.](elapsed-dataset.png)
