--- title: "Radio Button" description: "The radio button is similar to the CheckBox component, except for one special property. All radio buttons in the same Container (including the Root Container) will automatically be mutually exclusive." --- # Radio Button > The radio button is similar to the CheckBox component, except for one special property. All radio buttons in the same Container (including the Root Container) will automatically be mutually exclusive. ![](radio2.png) **Component Palette Icon** ![](radio1.png) The radio button is similar to the CheckBox component, except for one special property. All radio buttons in the same Container (including the Root Container) will automatically be mutually exclusive. This means that only one radio button can be selected at a time. Radio buttons are a good way to let the user choose just one of a number of options. Dropdown Lists are another good way to do this. ## Properties |Name|Description|Property Type|Scripting|Category| |:---|:---|:---|:---|:---| |Antialias|Draw with antialias on? Makes text smoother.|boolean|.antialias|Appearance| |Background Color|The background color of the component.|Color|.background|Appearance| |Border|The border surrounding this component. NOTE that the border is unaffected by rotation.|Border|.border|Common| |Cursor|The mouse cursor to use when hovering over this component.|int|.cursorCode|Common| |Data Quality|The data quality code for any tag bindings on this component.|int|.dataQuality|Data| |Enabled|If disabled, a component cannot be used.|boolean|.componentEnabled|Common| |Fill Background|If true, the label's background color will be drawn. If false, it will have a transparent background.|boolean|.fillBackground|Appearance| |Focusable|If a button is not focusable, you will not be able to interact with it with the keyboard. This means you can't "tab" over to it.|boolean|.focusable|Behavior| |Font|Font of text on this component.|Font|.font|Appearance| |Foreground Color|The foreground color of the component.|Color|.foreground|Appearance| |Horizontal Alignment|The horizontal alignment of the button's contents (text and/or image).|int|.horizontalAlignment|Layout| |Margin|The internal margin that provides padding for the contents of this button.|Insets|.margin|Appearance| |Mouseover Text|The text that is displayed in the tooltip which pops up on mouseover of this component.|String|.toolTipText|Common| |Name|The name of this component.|String|.name|Common| |Rollover|If true, the button may indicate that the mouse is hovering over it.|boolean|.rolloverEnabled|Behavior| |Selected|The current state of the RadioButton.|boolean|.selected|Data| |Styles|Contains the component's styles.|Dataset|.styles|Appearance| |Text|Text of this component.|String|.text|Appearance| |Vertical Alignment|The vertical alignment of the button's contents (text and/or image).|int|.verticalAlignment|Layout| |Visible|If disabled, the component will be hidden.|boolean|.visible|Common| ## Scripting ### Scripting Functions This component does not have scripting functions associated with it. ### Event Handlers Event handlers allow you to run a script based off specific triggers. See the full list of available event handlers on the [Component Events](scripting\scripting-in-ignition\component-and-window-scripting\component-events.md) page ## Customizers + [Vision Component Customizers](visualization-and-dashboards\understanding-components\component-customizers\component-customizers.md) + [Style Customizer](visualization-and-dashboards\understanding-components\component-customizers\component-customizers.md#style-customizer) ## Example ![](radio.png) Radio buttons inside a container will be exclusive therefore selecting one radio button will de-select the other radio buttons.
