--- title: "Multi-State Button" description: "This button is really a series of two or more buttons, arranged in a column, row, or grid. Each button represents an integer-valued state." --- # Multi-State Button > This button is really a series of two or more buttons, arranged in a column, row, or grid. Each button represents an integer-valued state. ![](multi-state-button.png) **Component Palette Icon** ![](multi-state-button-palette.png) This button is really a series of two or more buttons, arranged in a column, row, or grid. Each button represents an integer-valued state. Each state defines two styles for a button: the selected style, and the unselected style. Each button is automatically displayed with the correct style based on the current state (the value of Indicator Value). When a button is pressed then released, its state's value is written to the Control Value. To configure a Multi-State Button, simply drag a Tag that represents your state onto the Multi-State Button. This will bind both the Control Value and Indicator Value to that Tag. Now open up the Multi-State Button customizer, and define your states: their order, values and styles. Lastly choose if you want the buttons to be a column, row, or grid by setting the Display Style property. ## Properties |Name|Description|Property Type|Scripting|Category| |:---|:---|:---|:---|:---| |Antialias |Draw with antialias on? Makes text smoother. |boolean |.antialias |Appearance | |Background 3D? |Controls whether or not the buttons have a gradient-style background color. |boolean |.background3D |Appearance | |Confirm Text |The message to ask the user if confirmation is turned on. |String |.confirmText |Behavior | |Confirm? |If true, a confirmation box will be shown. |boolean |.confirm |Behavior | |Control Value |Bind this to the tag that controls the state. (Typically, this is bound to the same location as Indicator Value) |int | .controlValue |Data | |Cursor |The mouse cursor to use when hovering over this component. |int | .cursorCode|Common | |Data Quality|The data quality code for any tag bindings on this component. |int |.dataQuality | Data | |Display Style |The display style (rows or columns) for this N-state button. |int |.displayStyle |Appearance | |Enabled|If disabled, a component cannot be used. |boolean |.componentEnabled |Common | |Focusable |If a button is not focusable, you will not be able to interact with it with the keyboard. This means you can't "tab" over to it. |boolean |.focusableEnabled |Behavior | |Font |Font of text on this component. |Font |.font |Appearance | |Grid Cols|The number of columns if the Display Style is set to "Grid" mode. |int |.gridCols |Appearance | |Grid Rows |The number of rows if the Display Style is set to "Grid" mode.|int |.gridRows |Appearance | |Horizontal Gap |The horizontal spacing between buttons.|int |.hGap |Appearance | |Indicator Value|Bind this to the tag that indicates the current state. (Typically, this is bound to the same location as Control Value).|int |.indicatorValue |Data | |Mouseover Text |The text that is displayed in the tooltip which pops up on mouseover of this component.|String|.toolTipText |Common | |Name|The name of this component.|String|.name |Common | |Rollover |If true, the button may indicate that the mouse is hovering over it. |boolean | .rolloverEnabled |Behavior | |States |A Dataset that stores the information for the different states.|Dataset|.states |Behavior | |Vertical Gap|The vertical spacing between buttons. |int|.vGap |Appearance | |Visible |If disabled, the component will be hidden. |boolean|.visible |Common | ## Scripting ### Scripting Functions This component does not have scripting functions associated with it. ### Extension Functions This component does not have extension functions associated with it. ### Event Handlers Event handlers allow you to run a script based off specific triggers. See the full list of available event handlers on the [Component Events](scripting\scripting-in-ignition\component-and-window-scripting\component-events.md) page ## Customizers The Multi-State Button has its own Customizer. Here, you can define your states, change the order, values, and styles. You can organize your buttons to be a column, row, or grid by setting the **Display Style** property in the Property Editor. You'll notice that the Multi-State Button Customizer already has some preset states and pre-defined styles to help you get started. The Multi-State Button works by defining a set of visual styles that change based on a single State. When one of the buttons is pressed, its state value is written to the Control Value property and the Indicator value, and then the visual style will change. ### Multi-State Button Customizer Property Descriptions | Property | Description | |--|--| |Preview |Lets you preview each button's display style, states, and the selected style and unselected style as you configure it. |States |Shows a list of all possible states. You can add, remove, and the change the order of each state listed. Each state also defines two visual styles for a button: Selected Style and Unselected Style. | |Selected Style |Shows the visual style when the button is selected. You can configure the styles you want to change: **Text, Background Color, Foreground Color, Border** type, and even add an **Image**. | |Unselected Style |Shows the visual style when the button is not selected. You can configure the styles you want to change: **Text, Background Color, Foreground Color, Border** type, and even add an **Image**. | |Text |Text displayed on the button. | |Background Color |Color of the button | |Foreground Color |Color of the text | |Border |Type of border around the button | |Image Path |Relative path name for an image on the button | The Multi-State Button component in this example has its **Display Style** property set to **Grid**. Each button represents an integer-valued state. Each state defines two styles for a button: the selected style, and the unselected style. When a button is pressed, its state's value is written to the submit your changes property. The displayed state is based on the **Indicator Value** property. ![](msb-grid.png) + [Vision Component Customizers](visualization-and-dashboards\understanding-components\component-customizers\component-customizers.md) + [Style Customizer](visualization-and-dashboards\understanding-components\component-customizers\component-customizers.md#style-customizer) ## Example ![](multi-state-button4.png) |Property Name|Value| |:---|:---| |Display Style|Grid| |Styles|![](multi-state-button-styles.png)|
