--- title: "Check Box" description: "A CheckBox is a familiar component that represents a bit - it is either on (selected) or off (not selected). It is functionally equivalent to the Toggle Button component." --- # Check Box > A CheckBox is a familiar component that represents a bit - it is either on (selected) or off (not selected). It is functionally equivalent to the Toggle Button component. ![](checkbox1.png) **Component Palette Icon** ![](CheckBox2.png) ## Properties |Name|Description|Property Type|Scripting|Category| |:---|:---|:---|:---|:---| |Antialias|Draw with antialias on? Makes text smoother.|boolean|.antialias|Appearance| |Background Color|The background color of the component.|Color|.background|Appearance| |Border|The border surrounding this component. NOTE that the border is unaffected by rotation.|Border|.border|Common| |Cursor|The mouse cursor to use when hovering over this component.|int|.cursorCode|Common| |Data Quality|The data quality code for any tag bindings on this component.|int|.dataQuality|Data| |Enabled|If disabled, a component cannot be used.|boolean|.componentEnabled|Common| |Fill Background|If true, the label's background color will be drawn. If false, it will have a transparent background.|boolean|.fillBackground|Appearance| |Focusable|If a button is not focusable, you will not be able to interact with it with the keyboard. This means you can't "tab" over to it.|boolean|.focusable|Behavior| |Font|Font of text on this component.|Font|.font|Appearance| |Foreground Color|The foreground color of the component.|Color|.foreground|Appearance| |Horizontal Alignment|The horizontal alignment of the button's contents (text and/or image).|int|.horizontalAlignment|Layout| |Margin|The internal margin that provides padding for the contents of this button.|Insets|.margin|Appearance| |Mouseover Text|The text that is displayed in the tooltip which pops up on mouseover of this component.|String|.toolTipText|Common| |Name|The name of this component.|String|.name|Common| |Rollover|If true, the button may indicate that the mouse is hovering over it.|boolean|.rolloverEnabled|Behavior| |Selected|The current state of the checkbox.|boolean|.selected|Data| |Styles|Contains the component's styles.|Dataset|.styles|Appearance| |Text|The text displayed on the checkbox.|String|.text|Appearance| |Vertical Alignment|The vertical alignment of the button's contents (text and/or image).|int|.verticalAlignment|Layout| |Visible|If disabled, the component will be hidden.|boolean|.visible|Common| ## Scripting ### Scripting Functions This component does not have scripting functions associated with it. ### Event Handlers Event handlers allow you to run a script based off specific triggers. See the full list of available event handlers on the [Component Events](scripting\scripting-in-ignition\component-and-window-scripting\component-events.md) page ## Customizers + [Vision Component Customizers](visualization-and-dashboards\understanding-components\component-customizers\component-customizers.md) + [Style Customizer](visualization-and-dashboards\understanding-components\component-customizers\component-customizers.md#style-customizer) ## Examples ![](checkbox.png)
