title: "Email Notification Profile"
# Email Notification Profile
> Alarm notification is the act of sending an email message to a group of people when an alarm becomes active or cleared. In Ignition, this functionality is enabled by having the Alarm Notification Module installed which provides alarm pipelines and email notification.
Once you have your Email Notification Profile created in Ignition, you can notify people when alarms occur via Email. If the two-way setting is enabled, operators can also acknowledge the alarm by clicking the link in the body of the email.
Let's get started setting up an Email Notification Profile.
## How to Create an Email Notification Profile
1. Go to the **Configure** section of the Gateway webpage.
2. Select **Alarming** > **Notification** from the menu on the left side. The Alarm Notification Profiles page will be displayed.
3. Click on the **Create new Alarm Notification Profile** link.
4. A list of available alarm notification profiles appear. If any of the profiles are not displayed, it means the required module is missing, or faulted. (To verify that the Alarm Notification Module is installed and running, click on **Modules** from the menu bar on the left side). Choose **Email Notification**, and click **Next**.
5. Configure the settings for the Email Notification Profile, and then click **Create New Alarm Notification Profile**.
- Enter a **Name**: Email 1
- Click the **Enabled** box to enable Email notifications.
- Enter the **Hostname**. This is the hostname of the **SMTP server** that will be responsible for sending the emails.
- Enter the **Port**. The default is **Port 25**, but your mail server may be different.
- Enable **SSL/TLS** if you are using encryption.
- Enter your **Username** and **Password** if they are required.
- Click the **Two-way Enable** box if you want to make your Email Notification Profile two-way so that the operator can acknowledge the email. There is a link to acknowledge the alarm in the email.
:::note
You must have a connection back to the Ignition Gateway. So, if you are working from home and not on a VPN, you will either have to get on a VPN or expose your Ignition server on the internet. You can do this with port forwarding, talk to your IT department about it.
- **Auditing**: You have the option of attaching emails to an Audit profile so that Ignition can store all the events associated with the Email Notification Profile. (I.e., who is receiving alarm and who is acknowledging an alarm).
6. Once you create your Email Notification Profile, it will appear in the Alarm Notification Profiles list, and it will be running. You can edit the profile at any time to change any of the settings, and create as many Email Notification Profiles as you need.
:::tip
Once your Notification profile is created, you can use it in an [Alarm Pipeline](alarming\alarm-notification\alarm-notification-pipelines\alarm-notification-pipelines.md).
## Email Notification Profile Settings
### Email Settings
These settings specify the SMTP server that should deliver the emails. Multiple Ignition Gateways may be configured to use the same SMTP server.
| Property Name | Description |
| Use SMTP Profile? | If selected, this notification profile will use one of the Gateway-defined SMTP profiles, Otherwise, it will use the settings defined here. The setting should **NOT** be enabled unless an SMTP Profile has been configured elsewhere on the Gateway. Enabling this property causes the profile to **ignore** the Hostname and Port properties listed below. |
| SMTP Profile | If the **Use SMTP Profile** property is enabled, alarm notifications will be emailed using this profile. |
| Hostname | Hostname of the SMTP server to send email through. Only used when **Use SMTP Profile** is false. |
| Port | Port SMTP service is running on. Only used when **Use SMTP Profile** is false. |
| Enable SSL/TLS | Connect Using SSL/TLS. Only used when **Use SMTP Profile** is false. |
| Username | The username Ignition should use when communicating with the SMTP server. This is only required if the SMTP server expects authentication. Only used when **Use SMTP Profile** is false. |
| Password | The password Ignition will use to authenticate against the SMTP server. This is only required if the SMTP server expects authentication. |
### Two Way Settings
These settings allow users to acknowledge alarms directly from the Email Notification. When enabled, a link is included in the email that will redirect to a page on the Gateway.
| Two-way Enabled | Enables remote alarm acknowledgement. If disabled, users will not be able to acknowledge alarms from the email. |
| Gateway | Network address and port the Gateway is reachable at. Will be used in notification emails. |
| Send HTTPS Link | Specifies if the link should use an HTTPS link for SSL. |
### POP3 Two-way Settings
These settings allows Notifications to be acknowledged from when retrieved from a POP3 mailserver. Multiple Ignition Gateways may be configured to use the same POP3 server.
| Pop3 Two-way Enabled | Enable two-way notification via POP3. |
| Enable SSL/TLS | Enables SSL/TLS between the Gateway and the mailserver. |
| Delete On Acknowledge | If enabled, will delete messages from the inbox after acknowledging an alarm. |
| Hostname | The hostname of the mailserver. |
| Port | The port the mailserver is running on. |
| Username | The username the Gateway will use when authenticating against the mailserver. |
| Password | The password the Gateway will use when authenticating against the mailserver. |
| Custom Message | Allows an opportunity to provide an additional message to the notification. This custom message is in addition to the Custom Messages configured on the Alarm and the Notification Blocks in the Alarm Pipeline. |
| Polling Interval | The interval (in milliseconds) that the Gateway will check for new notifications. |
### Auditing
| Audit Profile | If an audit profile is selected, events such as emails and acknowledgements will be stored to the audit system. Note that alarm acknowledgements are also stored to the alarm journal. |
### Advanced
| SMTP Timeout | Timeout (in milliseconds) to use when connecting to, reading from, and writing to the SMTP server. |
| Debug Mode Enabled | Enable email session debugging. Information is printed to standard output (wrapper.log). |
| STARTTLS Enabled | Enable use of the STARTTLS command, allowing the connection to be upgraded to an SSL or TLS connection if supported by the server. This is not necessary for connections that are already SSL/TLS. Ignored when **Use SMTP Profile** is checked. |
